Autor Tema: Lg v50  (Leído 15180 veces)
Enylu
Re:Lg v50
« Respuesta #90 en: Diciembre 10, 2021, 03:05:10 pm »
👍🏻 claro sin problemas!!
En el iBasso dx160 se puede instalar hasta la versión 2.37.
Esta al parecer es la última que funciona sin ningún fallo, y es la que estoy usando yo.
Gracias a ambos por la info
DAPs: Shanling M6 Pro, Shanling M3X, etc.
IEMs: IMR Opus Mia, IMR Semper, etc.
anjobape
Re:Lg v50
« Respuesta #91 en: Diciembre 29, 2021, 01:43:06 pm »
Les he vuelto a escribir. Es cierto que tras la última actualización algunos temas que no podía escuchar en calidad máster ahora puedo. Pero muy pocos.
Me han respondido lo mismo.
Pero ahora ha sido una tal Pepsi 😂😂😂
Dec 28, 2021, 6:06 PM EST
Hello,
Thank you for contacting TIDAL Support. My name is Pepsi. I am sorry you are having this issue.  I will be happy to assist you.
Our Tech Team has figured out the source of this issue, it's connected to the internal player within both LG and iBasso devices.
Our developers are currently working on finding a resolution to this matter and we appreciate your patience in the meantime while it is worked on.
They do recommend in the meantime using an app like UAPP (USB audio player pro) as it helps provide the bit-perfect rate between TIDAL and your device since you're having trouble streaming bit-perfect with your current set-up. That in-between will help your device recognize the full unfold of the file and play it correctly.
We thank you for your patience as well in the meantime while our team works further on making this possible through the mobile app itself.
Let me know if you have any other questions, I'm always happy to help.
Feel free to check out our support page at support.TIDAL.com, It is a great way to make sure you are using the application to its full potential.
Have a wonderful day!
Thank you for using TIDAL!
Musically Yours,
Pepsi
TIDAL Member Support
Enylu
Re:Lg v50
« Respuesta #92 en: Diciembre 29, 2021, 03:05:32 pm »
Yo, como dicen por el sur, ya ni le echo cuenta a la versión del Tidal... jejeje
Lo actualizo en los daps que sí van bien y en los móviles saltar la actualización...
Gracias. Saludos
Nickcave
Re:Lg v50
« Respuesta #93 en: Enero 05, 2022, 09:30:50 am »
Me acaba de llegar Un LG V50,versión coreana, que es la mejor, tanto en audio, como en fluidez ,actualizaciones,etc.
¿Qué tal Sisco? Una duda... ¿Que diferencias hay en audio entre la versión europea y la koreana?
Gracias!
Re:Lg v50
« Respuesta #94 en: Enero 05, 2022, 09:49:49 am »
Gracias!
Hola..pues no lo sé ciertamente,pues ,no los he comparado A/B. Lo devolví antes de una semana,pues me dió problemas .
Ahora tengo como soporte Android un G7 thinq
De todas maneras,estoy plenamente metido en el ecosistema Apple,con sus cosas buenas y no tan buenas.
« última modificación: Enero 05, 2022, 09:52:21 am por stersa »
anjobape
Re:Lg v50
« Respuesta #95 en: Febrero 12, 2022, 06:35:32 pm »
Hoy justo antes de irme de casa de mis padres he probado a instalarle Tidal en el LG V30 de mi padre esperando encontrar la misma desesperación que me ocurre cuando reproduzco ciertos temas en calidad master en mi LGV50 que como bien sabéis no lo hace (salvo que lo bajes de calidad, como también sabéis) Y... PUM!! Los reproduce. He probado únicamente 2 temas porque mi hija tenía prisa x irse a estudiar pero los ha reproducido sin problemas. Mi cara 😳😳😳😳 no entiendo nada!!!!
blay
Re:Lg v50
« Respuesta #96 en: Febrero 12, 2022, 07:29:04 pm »
A ver si se ha actualizado la app.
O también puede ser otra cosa. MQA simplemente es que se reproduce como se ha grabado, que no ha sufrido ninguna modificación posterior. Pero ese MQA puede ser de mayor o menor calidad. No quiere decir que todos los MQA sean la hostia!!!
Hay MQAs de 24 bits de profundidad y frecuencia de muestreo de 96Khz o incluso de 192Khz; y hay MQAs de solo 16 bits y 44.1 Khz.
Seguro que el móvil no puede con los archivos más pesados de 24/96; pero si con los de 16/44. Y eso es lo que te habrá ocurrido.
El resto de música de 24/96, si no puede pues lo reduce. Pero si es MQA lo reduce también pero no te puede decir entonces que sea MQA porque lo está modificando. En cambio, si sí que puede reproducir el MQA porque es de 16 bits, entonces si que te indica que es MQA.
Fíjate en los datos de profundidad de bits y frecuencia de muestreo. A ver si van por ahí los tiros.  ;)
« última modificación: Febrero 12, 2022, 07:31:20 pm por blay »
Nickcave
Re:Lg v50
« Respuesta #97 en: Febrero 13, 2022, 06:24:01 am »
Sigue igual.... Se traba al pasar de algunos temas máster a otros hifi.
Ya desde hace tiempo uso sólo UAPP que no ocurre esto.
El problema está reconocido por Tidal (en Twitter se ha hablado de eso) y parece que es por el dac de los Lg.... Es curioso que cuando Tidal era propiedad de la empresa de Jay-Z no pasaba. Ahora la app está un poco dejada técnicamente.
anjobape
Re:Lg v50
« Respuesta #98 en: Julio 31, 2022, 04:17:02 pm »
He vuelto a probar Tidal después de un tiempo sin usarlo esperando a que se hubiera resuelto el principal problema por el que lo dejé y es que algunas canciones master no sd reproducen en mi Lg V50. Problema de sobra conocido pero que de momento no hay solución.
La versión que he encontrado que no tiene problemas es la 2.37.1 por si a alguien le pudiera valer.
Dejo la página para descargar todas lss versiones. Archivos apk sin problemas de instalación. Yo a partir de esta versión mi LG ya no reproduce algunos temas Master
Abajo en la página está para descargar todas las versiones.
https://mobile.softpedia.com/apk/tidal/2.37.1/
Jakoveron
Re:Lg v50
« Respuesta #99 en: Enero 28, 2024, 03:34:05 pm »
Buenas una consulta  , casi estoy por comprar
Un v50 (americano)por 150 euros ,  lo puedo ver en mano, el hombre me dice que aquí funciona perfecto..pero ahora que leí vuestros post ..
Otra cosa aprovechando la coyuntura a mí tidal con un
Samsung s9 antes me iba bien con los bose sport..
Pero ahora con los sennheiser algunas canciones no las puedo escuchar  , al parecer al ser por bluetooth  comprime..
Y se escucha fatal.
