Autor Tema: El hilo del "Sapphire amp" ( Funcionando :-D )  (Leído 149819 veces)
maty
    • Nauscopio Scipiorum
Re:El hilo del "Shapphire amp"
« Respuesta #30 en: Abril 13, 2014, 11:07:50 am »
Estaba leyendo sobre el Quad 405-2 modificado y hay un comentario que hace referencia al mismo op-amp que utiliza el Shapphire, el OPA 134, tal vez te interese:
-> http://www.dadaelectronics.eu/ForumRetrieve.aspx?ForumID=317&TopicID=97322&NoTemplate=False
Citar
As you have discovered, a Radio board with OPA 134 is significantly better than a CD board with TL071/072.  Also, bypassing the otherwise standard 44 altogether is better.
After the Radio board, the signal must pass through, depending on version of 44, 4 or 5 more TL071 or TL072 on the Tone Control board before it passes out the 44 and into the 405-2.  So if you do the upgrade to the whole 44, the difference you hear between the OPA 134 Radio board and TL072 CD board will likely be more significant still.  The effect is not linear with each opamp replaced nor is it fixed.  For fun you could upgrade the 44 and leave one CD board standard with TL072 and see how much it degrades the sound.
Last weekend I replaced the caps in my 44 with new Nichicons.  I used the best grades available for each of the values.  I had previously replaced the caps with very good but not high end caps 6 years ago.  The effect was very clearly audible.
The OPA627 is very nice.  My 405-2s both use them.  One has the full Net-Audio MKIII upgrade with PSU the other currently a standard PSU with full Net Audio 405-2 upgrade.  The Net Audio 405-2 upgrade is slightly different to a standard Dada upgrade.  I'd discussed this with EJP and Joost who examined my boards.  I can't comment on how a Dada 405-2 upgrade sounds because I've not done it yet.  However, I imagine it would be very similar especially if you use the same Opamp, driver and power transistors and also upgrade the chokes.
As nice as the OPA627 is, there are many on this forum who say the LME497x0s are better still.  I'm about to try them on a 34 when I get some time.
In conclusion, I strongly suggest you upgrade your 44 or sell it and change the input sensitivity of your 405-2's to match the 2.1VRMS signal you are feeding it...
Busco al respecto:
-> http://www.desmith.net/NMdS/Electronics/QUAD_upgrades.html
-> http://rockgrotto.proboards.com/thread/9280/sams-quad-405
« última modificación: Abril 13, 2014, 11:09:30 am por maty »
maty
« Respuesta #31 en: Abril 13, 2014, 11:12:59 am »
Si un día quieres probar algo mejor que el ALPS, el DACT CT2-10K-2, 128€ aquí:
-> http://www.dadaelectronics.eu/shop/dact
« Respuesta #32 en: Abril 15, 2014, 01:50:09 pm »
Perfecto, rápido y sin aduanas desde Japón.
feraldi
« Respuesta #33 en: Abril 15, 2014, 04:08:27 pm »
Ya te ha llegado?, anda que bien, ya irás contando y enseñando fotos del montaje..anda que no te lo vas a pasar bien.. :)
« Respuesta #34 en: Abril 15, 2014, 05:26:53 pm »
Pues si, la verdad es que ha sido muy rápido.
Montaré hasta donde pueda y luego le pediré ayuda a Rafa, que me he estado leyendo un poco el manual y cuando habla de cableado, offset y bias me quedo cuajado  :o  ;D ;D
« Respuesta #35 en: Abril 16, 2014, 09:30:19 am »
Hmmmm, placas en negro mate... esto va a sonar de lujo  ;D ;D
En unas horillas me he soldado casi todo; sólo me quedan los transistores pero esos los voy a situar con calma comparando el esquema con la placa porque no quiero conectarlos mal y liarla  :)
feraldi
« Respuesta #36 en: Abril 16, 2014, 10:19:34 am »
Estooo...tu has dormido esta noche David? ;D
Te esta quedando de primera, enhorabuena artista.
herdom
« Respuesta #37 en: Abril 16, 2014, 10:28:59 am »
Coño, si que va la cosa rapida, ha estas horas debe estar sonando ya  ;D ;D ;D
A ver si te funciona de primeras y lo disfrutas esta semana santa  ;)
« Respuesta #38 en: Abril 16, 2014, 11:07:46 am »
Nah, en un par de horillas largas estaba hecho, realmente se puede hacer mucho mas rápido, pero entre que quería asegurarme por triplicado de donde va cada componente y que tengo la punta gorda en el soldador se me demoró un poco.
Ya me he quedado sin diversión  :-[, tengo que esperar al resto de elementos... Mientras voy a leer lo del filtro Zobel, que es opcional y se lo he puesto, pero realmente no tengo ni idea de que es lo que hace, ni como ajustarlo ni si es lo mas adecuado para los LCD2 o HD800, y en ingles los tecnicismos me cuestan bastante... Las dudas del cableado, offset y bias las dejo para más adelante ;D ya os iré contando.
guein
« Respuesta #39 en: Abril 16, 2014, 12:40:46 pm »
Mola y de momento no parece muy complicado.
Como que lo más adecuado para unos HD800? los tienes en mente  :o :o :o?
Esperamos tus avances y futuras impresiones sonoras ;)
« Respuesta #40 en: Abril 16, 2014, 02:23:18 pm »
Los tengo en mente sí, pero sin prisa ninguna  :)
Aprovecho: si alguien de Madrid de confianza quiere tener unos días los LCD2 y me deja unos HD800 no me importaría  ;)
sludig
« Respuesta #41 en: Abril 16, 2014, 02:56:00 pm »
Lo has probado con los Audeze? Si es así, cómo dirías que va con ellos?
« Respuesta #42 en: Abril 16, 2014, 05:45:28 pm »
Nono, si sólo llevo lo que ves en la imagen  ;D  Aun me queda mucho para tenerlo funcional...
JuanB
« Respuesta #43 en: Abril 16, 2014, 06:10:14 pm »
Yo qué tu cambiaría los condensadores por unos bien gordos para que no se te aparezca el fantasma de Zarmack por tu casa, soldador en mano... :P
feraldi
« Respuesta #44 en: Abril 16, 2014, 06:24:02 pm »
Con lo buen tío que es Gerardo..mira que llamarle fantasma..oyoyoy.. ;D
