Autor Tema: Potencia de los amplificadores electrostáticos más conocidos.  (Leído 7830 veces)
Ahí dejo eso para que sea fácil de encontrar.  :)
-3000 volts peak to peak stator to stator (+/-750 power supplies) ------>KG TOGTE
-2400 volts peak to peak stator to stator (+/-600 power supplies) ------>KOSS ESP 950
-2300 volts peak to peak stator to stator (+/-575 power supplies) ------>KG’s new Silicon Carbide jfet based space heater
-2000 volts peak to peak stator to stator  (+/-500 power supplies)------>STAX T2, DIY T2, KGSSHV (ixys parts)
-1800 volts peak to peak stator to stator (+/-450 power supplies)------->KGSSHV (sanyo parts)
-1800 volts peak to peak  stator to startor (power supply unknown) ----> ELECTRA
-1600 volts peak to peak stator to stator (+/-400 power supplies) ------> BH, BHSE, singlepower ES1,ESX (after being modified to remove the 100V offset) Cavalli Audio Liquid Lightning
-1400 volts peak to peak stator to stator  (+/-350 power supplies)-----> KGSS,Stax T1,T1s,T1W,313,323,SRA-14s, SRM-1 mk2, SRM-monitor, Woo Audio WES
-1300 volts peak to peak stator to stator -----> STAX SRA-10s/12s
-1200 volts peak to peak (+/-300 power supplies, and +600 capacitively coupled)------> KG tube #1, ARISTAEUS ,HEV70, HEV90, RSA A10, SRM-300, Exstata, EGMONT CIROLAN SRM-1, SRM-3, Woo Audio GES, SRM-310
-1100 volts peak to peak stator to stator-------> STAX SRA-3s, STAX SRM-001 (when the batterys are at full power)
-1000 volts peak to peak stator to stator (+/-260 volt power supplies)------>RUDISTOR EGMONT
-960 volts peak to peak stator to stator------->STAX SRM Xh, SRM 212
-540 volts peak to peak stator to stator-------> Very early HEV70  (+525 volt power supply and tubes biased at 390 volts
bernat58
Re:Potencia de los amplificadores electrostáticos más conocidos.
« Respuesta #1 en: Mayo 19, 2022, 08:06:51 am »
¿Qué potencia tiene el STAX 6 SPIRIT que monta Zarmack?
