Autor Tema: GUSTARD X20  (Leído 1725 veces)
eldoctor
GUSTARD X20
« en: Julio 04, 2015, 10:12:59 pm »
Ya se puede reservar en ebay el nuevo GUSTARD X20 por $870 (envío incluido).
Han tardado 2 años en desarrollar este monstruo con Dual Sabre, que seguro dará mucho que hablar.
http://www.ebay.com/itm/GUSTARD-DAC-X20-Super-Ultimate-HIFI-DAC-2xES9018-XMOS-USB-384KHZ-DSD64-128-/111708547958?pt=LH_DefaultDomain_0&hash=item1a02592b76
Fuentes: Macbook Pro>Audirvana+
Amp/DACs: Gustard H10 / Hifimediy Sabre 9023 U2
Auriculares: Sennheiser HD600/ Koss Porta Pro mod Hartmut Alt/ Sennheiser PX100 /
Repros: iphone 4/ipad 4
eldoctor
Re:GUSTARD X20
« Respuesta #1 en: Julio 04, 2015, 10:22:37 pm »
Features:
1. Dual ESS Technology Sabre Reference 32bit ES9018 DAC chip,R and L sound Chanel one on each side。
2.Automatic adaptation master clock technology and Asynchronous master clock technology。
Two clock mode can be freely selected.
3. XMOS 32bit USB receiver chip which is best performance asynchronous USB audio solution.
4.CPLD programmable logic device. Soft control ES9018.
5. Three files gain, volume can be adjusted. Attenuation adjustable from 0 to -99DB.
6. TFT LCD screen, adjustable contrast.
7. Power supply with two O-type transformers, Digital and Analog independent power supply, and use Discrete Components regulation Voltage stabilization.
8. Full balance Discrete components Analog Line. Balance / RCA output simultaneously.
9. Digital Input: balanced Spdif AES/EBU port, RCA, Toslink Optical input and USB,(Key switch)
10. Both 110/120v and 220/240v version supported.
11.Power Supply: AC 230V 50 / 60Hz (AC 115V 50 / 60Hz),Power Consumption: <50W
12.Dimensions (excluding protruding part): W 380MM * H 65MM * D 260MM
DAC Specification:
ESS Technology ES9018 Sabre Reference 32-bit DAC
8 mono to 2 stereo configuration,four D/A converters per channel
Digital Input:
Coaxialã€BNC:
PCM:16-24bit /44.1ã€48ã€88.2ã€96ã€176.4ã€192 kHz
DOP:DOP64
optical:
DOP:DOP64
AES/EBU:
DOP:DOP64
IIS:
PCM:16-32bit /44.1ã€48ã€88.2ã€96ã€176.4ã€192ã€352.8ã€384kHz
DSD:DSD64ã€DSD128ã€DSD256ã€DSD512
DOP:DOP64ã€DOP128  DOP256ã€DOP512
USB: 16-32bit / 44.1ã€48ã€88.2ã€96ã€176.4ã€192ã€352.8ã€384 kHz
DSDx64(2.8224MHz)ã€DSDx128(5.6448MHz)
bmbnct
Re:GUSTARD X20
« Respuesta #2 en: Julio 05, 2015, 08:37:23 am »
Pfff... Vaya pinta tiene :o
Desde luego por números es imbatible. Aunque a estos niveles lo importante es que la sección analógica acompañe, que viéndo el interior parece que si.
Me lo apunto y espero la review de alguien que lo escuche.
Auriculares: Audeze LCD4, Denon AH-D7000, Sennheiser HD 800, Hifiman HE-400i
Amplificador auriculares: Moon 430HAD, Icon Audio HP8 MKII SE
yebra
Re:GUSTARD X20
« Respuesta #3 en: Julio 05, 2015, 11:00:27 am »
Yo tengo el X12 y estoy muy contento con él
eldoctor
Re:GUSTARD X20
« Respuesta #4 en: Julio 05, 2015, 11:30:21 am »
Esta previsto que funcione ya este mes la web y tienda online del distribuidor oficial de Gustard, Seowon Audio.
Era lo que tenían pendiente para ofrecer un servicio técnico y soporte a sus clientes y tramitar garantías.
http://www.seowon-audio.com/
A ver si alguna tienda española se anima a contactar con el nuevo distribuidor y traer los equipos de esta marca  :)
« última modificación: Julio 05, 2015, 11:35:25 am por eldoctor »
yebra
Re:GUSTARD X20
« Respuesta #5 en: Julio 05, 2015, 12:04:21 pm »
Yo lo compré directamente en Inglaterra, creo que la tienda era Kidult
mikibond
Re:GUSTARD X20
« Respuesta #6 en: Septiembre 20, 2015, 05:21:22 pm »
He visto que ya hace unas cuantas semanas que este DAC se encuentra a la venta en Ebay y tiendas chinas. Estoy planteandome realmente el comprar este bicho, pero la escasa información que se encuentra sobre el me echa un poco para atrás.
Sobre modelos de la misma marca en amplificadores veo que muchos de vosotros hablais que gozan de una relación calidad-precio casi insuperable.
Pero la duda que me asalta es si la durabilidad de la marca está a la altura de los equipos a los que presume competir con un rango muy superior de precio.
O lo que es lo mismo, no me voy a gastar casi 800€ en el clon chino del iPhone solo por unas especificaciones. Alguien puede aportar algo sobre esto??
Por lo que al igual que muchos de nosotros, mi intención es la de hacerme con un equipo de DAC + Ampli (por separado) con la suficiente calidad para quedarme con el muchos muchos años, y solo preocuparme de disfrutar de los distintos auriculares que hay en el mercado.
Por lo que ademas me gustaría proponer el hacer otra encuesta como la que habeis hecho anteriormente, donde escogiais los mejores Auriculares, Dacs, amplis, etc de 2013, solo que con los equipos y precios actualizados que hay hoy en día. Gracias a esas encuestas es por lo que conocí este foro y me decidí a adentrarme un poco màs en este mundo.
Esto sería en beneficio de todos ya que la gran mayoría no podemos gastarnos 1.000, 2.000, o 3.000€ en solo un aparato sin "despeinarnos" y las inversiones que hagamos deben estar lo mas contrastadas posibles.
Espero la colaboración de todos GRACIAS!
pupas
  • Aprendiendo siempre.
Re:GUSTARD X20
« Respuesta #7 en: Septiembre 20, 2015, 11:56:17 pm »
He tenido la oportunidad de probar durante unos días el DAC X12 ( de un amigo) con mi amplificador Gustard H10 y suena con una claridad inmejorable, superando al dac TEAC que dispongo actualmente.
Sobre su durabilidad no te podría asesorar, ya que son unos productos recién sacados del horno ( meses) y la garantía es china, aunque su servicio técnico empezará a funcionar dentro de poco ( como bien dicen en los post de arriba), pero lo que no hay que dudar, es que relación calidad-precio es abrumadora ( ¿cuanto habría que desembolsar para igualarla con productos de marcas reconocidas?).
Esa incertidumbre de durabilidad, es el "precio" que has de pagar si te decides por ellos ( y mientras que "te quiten lo bailao") ;) ;) ;).
Pupas.
iMac con audirvana
Akg Q701,Hifiman HE400i, ZMF XVibro,Audeze LCD 2.2 ,Sennheiser HD800,KOSS 95X Massdrop,STAX SR404S, STAX SR-L700MKII
Topping E30+ Pathos Aurium
Topping D10 Balanced + Monolith THX AAA 877 Balanced
Audeze Deckard
DAC Hifimediy sabre + Gustard H10
Dot MK II +6N6P+ VOSHKOD EV 6ZH1P
Cambridge Audio Dacmagic 100 + STAX SRM-006tA
